e-cutout stuck closed
My McCord e-cutout is stuck closed. I put a voltmeter to it and it read 12 volts, but its stuck closed. It's probably an elec. motor or something. Is the motor a cost worthy part to replace, or should I just get a new one? Do any supporting vendors sell e-cutout parts? If any vendors could also speak up on possible costs of parts or a new unit, I would appreciate it, thanks.
mine does the same thing, its the connections at the motor have someone hold the button open and get under their is wiggle and **** on the connection at the motor, I ended up pulling my heat shrink off and messing with them, i got to get time and fix it though.
I killed three cutout motors before I gave up and ditched the idea alltogether.
Stupid cutouts cost me 7rwhp (closed) and only gained 10 (3 over not having them) when open.
Originally Posted by eLTwerker
has anyone else experienced this? Lower dyno #s with closed cutout vs. no cutout.
Hell, I don't know physics, and it makes perfect sense to me. The only way it wouldn't cause a power loss is if it had a flap, that when closed made a perfect closure over the exhaust pipe, and when opened then flopped over and obstructed the exhaust pipe which in turn would divert exhaust out of the cut-out. Please tell me you follow what I said, so I don't have to bust out ye ole M$ Paint
