Hard to find P/N#'s
Hard to find P/N#'s
Going to add a bunch of new info to a current sticky soon and Im looking for some PN# that you guys might like added.
Stuff thats hard to find, the whole point of this is to eleminate threads asking 'whats the part number for the Hotcam?????????????'
So if you guys have any usefull ones feel free to post up.
IE: Frequently used Cams, AC Delete, Opti Swap (Non-Vented to Vented) etc...
Tony.
Tony.
Well there's one thing in the sticky that's not accurate, and I tried to PM the thread starter but his inbox was full. I'll try and find it. It's something that has to do with the TA GT. I'll edit when I find it.
EDIT: Here it is
Cold Air Induction Package (same as SLP Cold Air Induction) (from 97 Firebird GT) = 12371043
on this page
https://ls1tech.com/forums/showpost....8&postcount=18
That P# is this:
The correct P# would be nice, or just remove it :\
Also, the optional body kit off the base model car would be nice to have P#s for. I don't remember it's RPO, but someone showed me a pic in a thread we had going in the Firebird section, and it looked really nice.
EDIT: Here it is
on this page
That P# is this:
Originally Posted by GMPartsDirect
GM PART # 12371043
CATEGORY: Belt or Chain, Engine Timing
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $60.00
OUR PRICE: $43.68
DESCRIPTION: CHAIN PKG
Timing Chain Kit "Single Roller Design" This special performance single roller design timing chain kit can be used on all 1987 and newer small block engines with roller lifter camshaft, except LT1, LT4, and 1997 and later LS1. This kit is quieter than the double roller chain. This kit includes the following components: camshaft sprocket P/N 12552129, crankshaft sprocket P/N 14088784, chain P/N 14088783, retainer P/N 10168501, retainer P/N 10088128, three bolts P/N 9424877, and two bolts P/N 14093637. Use these components for single service requirements. They will not work on flat tappet camshafts.
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $60.00
OUR PRICE: $43.68
1LE A/C Delete Pulley: 10115875
1LE Intake Elbow Non-Vented: 25147210
1LE Intake Elbow Vented: 25147187
Non-Vented Opti: 10457702
Vented Opti: 1104032
LT4 Hot Cam Kit: 12480002
LT4 Hot Cam (Indv): 24502586
EDIT:
LT1 knock module (from 93-95 F-body) (AC-Delco #213-96) = 16177700 (formerly 10456126)
On page
https://ls1tech.com/forums/showpost....5&postcount=14
Error in the years. 93's is waaaay different, and not removable w/o soldering.
Originally Posted by Formula350
Those are all already listed in the parts number section of the Newbie FAQ.
Tony.
Tony.
Going by what Tony said in the first post
I know it's useful, but it's already there lol It's not even hard to find.
Originally Posted by infinitebird
just fyi but there's a ton of part numbers listed here if you want to add these: http://shbox.com/1/Parts.htm
Sadly, this link is dead :\ Listed above the part number sections.
http://www.1le.net/docs/1le_specific_parts.html
Proof people don't read stickys or use the search function anyways.
OK So here's my idea then. MOVE the whole P# post, to it's own sticky. Then we can have a category, that is already double posts of currently listed items, that are "Hot Items", or to that extent. The common parts people want to use/upgrade to. Maybe not have a 1LE suspension section, but a full 1L3 PACKAGE section, to house everything 1LE, instead of having it scattered.
