What spark plugs yall use.
Hey yall what spark plugs do some of you use. im a stock lt1 (sucks) and as yall already know the highest mileage lt1 as well. Im trying to get more out of my car (tune up) so what spark plugs you use i was going with the NGKs But i dont kno what set to get.
On a stock motor the TR55s work well, I found them to be a little too hot with the current compression so I run my leftover stock of them in my wagon.
Autolite 106 might work OK for you too again they can be a tad hot for modified motors but seem to be good for stock and they are easy to find as your nearest Walmart.
I use Autolites as well but I have read some debate on the actual heat range of the 106. I thought it was a stock heat range and 104 was 1 step colder, and 103 2 steps colder. But I have read that 106 is 1 heat range above stock. I take it you have actually verified this however.
I would just buy a cheap copper plug. The Delco's are platinum and kinda expensive. Fine for a stock/bolt on car and will yield several miles of use, but no extra fuel economy.
The NGK TR55s gapped at .055" have worked great in my past experiences. It really isn't worth going with the Iridium ones, the normal TR55s work great. You can find the NGKs typically at any local DAP.
I'm currently running NGK TR6s gapped at .035" for the bottle. No complaints with these at all either
