car broke after WOT run
I just did a WOT run to 80......and afterwards I hear a clacking sound coming from the engine bay. All the gauges look good.
I pull over, shut it down, restart, same thing.
pop the hood.....and it looks like the noise is coming from under the T-stat.
So I am thinking opti or water pump. I was able to drive the car fine home......rpm's seem fine. Around idle it started acting weird, kinda bucking alittle like it was about to die from too much load, so I kept the rpm's around 700 and it was fine.
Drove it home, now its cooling down.
any thoughts?
any thoughts?
Here's a video.
http://s2.photobucket.com/albums/y2/...t=DSCF0562.flv
there is a strong smell of gas when it is running, and little puffs of white smoke out the exhaust. Its also running really rough.
When I put a screwdriver against the engine block, I can feel the grinding that is making the noise......but when I put the screwdriver against the top of the water pump, it is 10x worse there.
Leads me to think its something up front.
any help?
I really dont know what I am doing.
any help?
hard to diagnose over the net, could be the waterpump, timing chain sounds like at a guess, is the waterpump dripping out of the weep hole on the bottom of it? It might be your chain and it's throwing timing off & running rough.
i was thinking timing chain as well. i just dont see a water pump causing it to run rough even if the impeller went out in it. but since the water pump is driven by a gear thats turned by the timing chain i could see the issue sounding like thats where it lies.
So should I order a new chain........or what?
I am gonna start taking it apart later today.
Do you think I need new gear sprockets?
Also, should I get the LT4 chain, or the GM heavy duty set?
thanks.
thanks.
thanks.
thanks.
Any pointers on what order i should tear it down?
I've never done this......
as promised, this should with a manual get you going.
http://www.gmhightechperformance.com...eliable_build/
well, I was looking at timing sets, and the LT4 sets wont work w/o me changing alot of stuff, since I have a 93.
Argh.
While I have the front apart, how much harder would it be to put a cam in?
Argh.
Argh.
Argh.
I dont think I have the money to change all that......
What about the timing kits? Do you know what I can use since I have a 93 engine?
I found a comp cams kit, but its $510.....kinda expensive
You could use a standard SBC chain instead of the LTx style since you won't need the w/p gear......that is if you change to an elec. w/p. Also there will be less load on the front cam bearing from driving the w/p all the time.
