after pacesetter lt install
ive had a few problems after the install of course the loss of low end and when i have the car in a high gear at low rpms the shifter shakes but before i did the headers it didnt do that some other details i didnt put the egr block off plates on but i pinched the tube shut and i didnt do a tune yet i thought i might have torn the trans bushing havent looked yet
did u check all ur spark plugs, wires ,order they are one the opti(if u changed wires) i no when i did my headers #5 cap fell off the spark pluga nd i could really tell my car shock real bad so just check all plugs to rule that out
The lt's could cause a false knock which could cause your timing to retard. You might need a tune and a LT4 Knock module.
Sounds like you need a coil and wires. I would recommend the Thunder racing's Over The Valve Cover wires kit with heat shields. I went through a lot of different wires trying to chase down my miss problem until I got these, haven't had a problem since.
Originally Posted by HungryMan87
with the lt4 knock module do i need a tune or are you saying a may need a tune to fix it
