Time to do some mods...
What to do first? I have a 94 TA, with 180K, and a new NAPA motor with 3K. The car is an auto with the 2.73 rear end. Take off is kind of weak, nothing like the Nissans I build, but I figure I can change this. Glancing through the Summit catalog, got me thinking of changing out the rear end first, maybe going with a 3.73. Can't decide on gear though, hope to swap to a 6 spd within the year sometime, and also going with a turbo setup here within the year too. I just want to bump up the fun for now, but still do things that will benefit my later modifications. What should be the first few things to install on a stocker? Budgeting about $500 a month to go towards the car.
i like my 3.73s. some people try to get me to go higher, but i'm not looking to do that. 3.73 is a good median. i've heard good things about 3.42 too... they're slightly less aggressive.
pacesetter coated Lts and ORY
find a good used stall if youre gonna keep the auto for a little while
3.73 gears
drag radials
lower control arms and relocation brackets
torque arm
CAI
subframe connectors and panhard bar
each thing(s) are per month for your budget.
3.73 gears
drag radials
torque arm
CAI
So I was looking in the Summit Catalog, and talked to the guys there, and they're saying around 2-300 for the gears and 125 for the install kit, pretty easy to do yourself? Think I should go this route first?
The general consensus on the gear is this:
Naturally aspirated - 3.73
Turbo - 3.42. The turbos like the load of the higher gear. I am extremely pleased with mine.
And be sure and get the gears made for the 2-series carrier, which is what you have. And get the full install kit, with the bearings and everything.
