Balancing and Blue Printing?
Originally Posted by skinnies
Yes you want to balance it if you go with aftermarket pistons. In that case though, pick up some rods also, they aren't much more!
I still suggest the 6" Scat 7/16s bushed I-beam rods and the Mahle powerpack pistons with a 1.250” compression height -5cc piston. This rod piston combo ends up lighter than stock and your balancer will be removing metal from the crank to balance the assembly so you end up with a lighter stronger rotating assembly.
"Blue printing" is alot more than checking your tolerances. Blue printing a block is a very in depth machining process that ensures all of your specs will be perfect.
Originally Posted by dhdenney
Isn't blueprinting simply where the machinist mics a piston, mics a bore, then works with that specific cylinder machining it specifically based on the micrometer's readings? Then he mics the crank journal, mics the main, then machines accordingly........
Mr. Cheese is right, Blue printing is far more in depth than just basic machine.
Such as: (To name a few.)
cylinder bore diameter, Cylinder wall taper, Piston diameter,
Deck height of block Bearing clearances,
Crankshaft end play, Piston to valve clearance, Bolt torque specifications,
Lifter bore diameter and alignment. Piston skirt taper, Piston to wall clearance
Piston ring end gap, Rod side clearance, Valve adjustment,
Degreeing the camshaft, making sure correct oil pressure during priming.
Align hone checked and re-machined if needed.
Cylinders are bored to exact specifications.
Cylinders are precision "honed" with torque plates, Deck surfaces are machined in reference to the crankshaft centerline,
Blocks are hand de-burred, bolt holes are checked and re-tapped.
All internal parts are de-burred, hand washed and inspected.
Pistons, pins and connecting rods are pin fit to specification.
Crankshafts are computer balanced to within .5 grams or less.
Crankshaft oil holes are chamfered Crankshaft bearing surfaces are micro polished.
CC checking chamber size for correct compression Surfacing to insure deck flatness.
Setting spring height & retainer to guide clearance.
All bolt holes would be re-tapped, cleaned and oiled, as well as their mating bolts.
Any surfaces refinished will have all holes chamfered, and any casting burrs or irregularities will be ground away.
The V type block will be align bored to maintain perfectly equal deck heights and keeping the crankshaft parallel to the decks.
All rods are reworked so they are EXACTLY the same length from crankshaft centerline to wrist pin centerline.
also checking ring side clearance in piston groove.
All these are parts of "blue printing".
Checking things with a mic is something any engine builder would do.. or at lease "should" do. It's the little things the seperate the winners from the loosers.
