Weird Noise
Weird Noise
I noticed lately (past week or so) my lt1 makes a weird noise usually most noticeable during start up. It's a whine almost sounds like a loud fuel pump under my hood. I know lt1s are noisy but this is worse than it normally is. It doesnt change pitch or anything when the rpms change its just a high whiney noise. I looked under the hood and I just cant specify where it is coming from. any ideas?
If it were belt wouldn't it change pitch as it turned faster? I had a truck once that needed an idler pulley (bearing bad) and when you sped it up, the pitch changed noticeably.
