True Duels ?
True Duels ?
Been thinking about going true duels. I have LT, 3" ORY, No Cats, 3" Magnaflow the rest of the way back.
Want to know if anyone that had a similar set-up and went to TD, has any dyno numbers to show if there were any gains in HP/TQ?
Originally Posted by nighthawk15
On a near stock car you won't get a significant power gain. The only reason to do it is if you like the sound of TDs better.
Currnet Best 12.98 1.94 60ft 95 T/A 106.34 MPH LT1 Functional Ram Air 52 mm TB w Foil Taylor wires MSD coil UD Pulleys SFC LCA 21 mm RSB BMR Adj TA Transgo SK Poly Mounts & bushings DynoTuned Pace Setter LT 3"Off Road Y-Pipe No Cat 3" Magnaflow exhaust, 502 CC, 1.6 rr, gasket matched intake to heads and heads to block.
i just did my true duals on friday the car is much nicer now.
the sound inside is quite docile,i used 2.5"pipe X-pipe single chamber flomasters with tailpipes it has a very distinct sound,if i gained anything it was at the top end but hey i like it.
Ah ok I didn't see all that before. It still probably won't give a whole lotta gain most likely because your current system already flows pretty good, but hey if you like the sound go for it. if you do get much of anything, like said in the post above me it'll probably only be up top.
