plate that attaches under throttle body?
hey guys. the plate that attaches to the underside of the throttle body, where the iac valve is located, is where the coolant flows correct? if i am going to do the tb bypass, can i cut these lines off to clean up the looks, and i wont need the gasket either right? i havent actuall seen one of these engines together in person, so this is just an assumption. i already have the throttle body to intake gasket and a tb plate gasket, so no need to buy the gasket for the bottom plate correct? thanks guys
