Double roller timing set install?
Old 08-02-2007, 03:00 PM
Z 2 8's Avatar
Default Double roller timing set install?
I got the Edelbrock Timing set # 7801 and I just wanted to be sure that it works with my motor ok. Also, when you install it, do I line the circle symbol on the crank sprocket with the arrow, or the circle on the cam sprocket?
I don't think it's going to fit though...I guess I'll have to go with a good single...
Old 08-02-2007, 03:24 PM
92LT1RS's Avatar
do you have an electric waterpump? if not, then no it won't fit. and it should come with instructions on how to line up the timing marks.
Quick Reply: Double roller timing set install?
