summit ring and pinions
Old 08-03-2007, 07:53 PM
LT1Falcon's Avatar
Default summit ring and pinions
anybody ever try them? they are only 125 dollars and i was wondering what the quality of them are. crap?
Old 08-03-2007, 08:36 PM
Mighty Whitey's Avatar
not sure about the summit brand gears, but I ran a Jeg's brand gear in my 9", I think it fit better on the carrier than the Motive gear I broke did!
very minimal gear noise when setup correctly too!
Old 08-03-2007, 11:54 PM
GOaT Cheese's Avatar
Summit doesn't make gear sets. They are probably produced by Superior, or American axle, or Richmond. If you call and ask they might tell you.
Old 08-04-2007, 07:58 AM
LT1Falcon's Avatar
well they are the summit brand gears, im not sure who makes them, i dont really care either, im just wondering if they are good quality, or at least good enough for my setup (practically stock motor, a4, 7 inch tires, no slicks).
Old 08-04-2007, 10:02 AM
1994t/a's Avatar
I was wondering about the quality of these gears too...i was gonna buy some from jegs but i saw summit had these for quite a bit less.I ran some cheap gears in another car i had with a 10 bolt and a ZZ4 crate engine.they where great....really took alot of abuse and very quite.think i paid about $160 for them.
Old 08-04-2007, 10:12 AM
indirocz28's Avatar
I recently installed a set of these gears in my 94 along with a Zexel Torsen differential.
I went by the spec's on the gears and everything is nice and set up to the measurements they want. I have only got about 200 miles on them but I ran them through a few heat cycles and have launched the car from about 5,000rpm and they seem to work fine. Car took off really good too.
I notice a small humm now and again but its nothing major. I was expecting that anyways. I was told that i would probably have a slight hum with a jegs or summit brand gear set. Apparently richmond runs thier gears together from the factory to make them kinda start to wear together as the Summit or Jegs brands do not.
They are a matched set btw and so far i am really happy with them.
Old 08-04-2007, 02:21 PM
LT1Falcon's Avatar
ok thanks, sounds like they might be a good enough set. anybody have any complaints at all? also, what is the best installation kit for the money? not necesarily the complete overhaul and installation kit, but just enough to to get the new gears in
Old 08-04-2007, 02:22 PM
dhdenney's Avatar
If you are going with a Summit ring and pinion, why not go with one of their basic kits as well?
Old 08-04-2007, 02:25 PM
LT1Falcon's Avatar
true true, i was just wondering if there was a better deal (not necesarily price but what you get too) with a different set. so you think that is good? dont want to get surprised and not get everything i need
Old 08-04-2007, 02:53 PM
eLTwerker's Avatar
Watch out if they're made by Richmond: noisy as hell! You'll hate it if it hums like mine did.
Old 08-04-2007, 03:13 PM
LT1Falcon's Avatar
ok i thought richmonds were the ones everyone wanted
Old 08-04-2007, 03:32 PM
indirocz28's Avatar
Here are the part numbers i went with for my 94 camaro. I did 4.10's for the 3 series carrier and the summit rebuild kit.
If you have a 10 bolt and are going for 4.10's you will have to get like a dremel and kind of grind down the center pin so that it will clear the gear teeth. Or on a Zexel, grind down a small portion of the block for the same reason.
Part numbers : SUM-741015 Gears SUM-G7821 Install kit
Hope this helps!
Jeff
Old 08-04-2007, 03:40 PM
LT1Falcon's Avatar
ok thanks man, so you havent had any problems with yours? i will be going with 3.73 so i shouldnt have to grind anything right?
Old 08-04-2007, 04:47 PM
scorpion_z28's Avatar
Dont know why Richmonds are all noisy even when they are set right(not like the are easy to) they still hum alot.
Old 08-06-2007, 06:23 AM
indirocz28's Avatar
No so far everything has been good. I believe that the only ones that require modification to the center pin or block is the 4.10's. I am not 100 % but im pretty sure.
Good luck, and take your time doing the install.
Old 08-06-2007, 12:37 PM
LT1Falcon's Avatar
ok thanks a lot
Quick Reply: summit ring and pinions
