re-assembly blues... help a brother out!
Old 08-05-2007, 11:09 PM
A-man930's Avatar
Default re-assembly blues... help a brother out!
I need pictures of the mounting bracket and coil on the lower driver's side... I got carried away doing the water pump that I forgot to take a picture of how everything came apart Now I've looked at everything so long that I'm not really sure of anything! I'm stuck on the mounting bracket for the AIR pump and how/where it mounts in relation to the ignition coil. I'm also not positive where that group of three ground wires go... your help is appreciated more than you know! Also, is it a problem that I didn't replace the o-ring for the wp driveshaft on the motor-side? (the new pump had one on there already...)
Old 08-05-2007, 11:11 PM
urbanhunter44's Avatar
The ground wires go on the bolt to the right of the ICM, iirc.
www.shbox.com will answer all your questions
