BAD coolant leak
Old 08-06-2007, 12:27 AM
silverbirdlt1's Avatar
Default BAD coolant leak
ok so i drive to sonic.. get out and coolant starts leaking from somewhere from my car.. ok, overflow i think.. nope. It keeps leaking ALOT. i drive it home, stays in the normal temp range and it leaks ALOT more. so i crawl up undereath it and it is leaking from something, i have no idea what (cant see where exactly) from right above my opti... HELP!
Old 08-06-2007, 12:29 AM
ws6t3rror's Avatar
probably from the water pump weep hole, in which case its time to order a new one.
Old 08-06-2007, 12:35 AM
ok.. it looked like MAYBE it was coming from that but i couldn't really tell for sure... why would it do that?? and it was a lot of coolant.. im probly out by now lol...
Old 08-06-2007, 03:32 AM
the_merv's Avatar
It's means your Water Pump is about to go to ****..
Old 08-06-2007, 03:59 AM
infinitebird's Avatar
Old 08-06-2007, 04:16 AM
the_merv's Avatar
Originally Posted by infinitebird
Old 08-06-2007, 05:35 AM
Bluestreak95's Avatar
you should probably quit driving the car or replace the pump asap. before you destroy the opti..right when a water pump goes or is going its not uncommon to see that much coolant coming out....its unreal the amount that can come out of the weep hole and the shaft.
Old 08-06-2007, 01:45 PM
Formula93's Avatar
Get an Electric water pump, you won't have to worry about it shitting on your opti anymore
Old 08-06-2007, 09:53 PM
well... me and a buddy had at it today and it is freaking RETARTED hard! i know its not supposed to be that way, but it was A LOT more than the "6" bolts and its off scenario.. we had to take off quite a few more parts to even get to half of the bolts.. 3 hours today, and only got it off.. geeze its stupid...
Old 08-06-2007, 11:19 PM
Formula93's Avatar
I had mine off in probably 30-45 minutes, what problems did you encounter?
Old 08-06-2007, 11:24 PM
the_merv's Avatar
Yea..it's not that hard to do..I did mine completely in about an hour and a half..
Old 08-06-2007, 11:31 PM
TXFORMULA's Avatar
hey did you check the radiator for leaks as well?cracks etc? mine was leaking pretty bad and come to find out there was a crack in the plastic part of the radiator.
Old 08-06-2007, 11:35 PM
the_merv's Avatar
^^ Just happened to me..
Old 08-07-2007, 12:29 AM
Lt14mla's Avatar
ill third that lol, however it it its drippin from where u say it is, then it sounds like ur weephole. replace it.
Old 08-07-2007, 10:55 AM
dhdenney's Avatar
He may have still had the air pump and stuff to work around as at least one of the driver side bolts shares the air pump bracket. And the farthest right bolt is behind the PS pulley but I can usually turn the pulley and get an extension in there. Might be kinda difficult if you've never done it before.
Old 08-07-2007, 02:07 PM
scottso's Avatar
Definitely - I read a lot of posts before I attacked mine. Determining what needs to be removed on the fly will take a lot more time. It's always good to hear experience from others.
What I hate the most is bathing in the friggin coolant as you pull bolts - other than that its just turning wrenches.
Old 08-07-2007, 02:40 PM
Lt14mla's Avatar
haha yea i must say i did smell like coolant for a long time after
Old 08-07-2007, 07:53 PM
James Montigny's Avatar
Most people have trouble the first time.
It gets easier over time LOL
It's also a good excuse to upgrade to an e-water pump
Old 08-11-2007, 12:23 AM
hey guys thanks for all the info, got it done two days ago, running great.. got some headers in as well and now were tackling that (and its been hell!). again thanks and if any one has some tips for putting in LT's that would be great! (got everything off, just having trouble getting them in now
Old 08-11-2007, 12:24 AM
and btw.. yes the coolant bath is superb! lmao...
Quick Reply: BAD coolant leak
