LE Edelbrock LT4 intake/Custom Rad setup
Originally Posted by Transamman25
? .... If i have Edelbrock Performer LT1 heads can i run the LT4 intake ?
Otherwise, if you ported the heads to match the intake, yea it'd work fine. I'd just go with the LT1 version personally. (Not that I can, w/o converting to 94+ injection )
How much did the intake and TB cost? It looks really nice together!
What are the specs on your radiator?
nice set up.. im sure if you put a fan shroud on it would cool it that just that much more
It's really hard to make out on my monitor, but did you cut the whole original upper crossbrace out and weld in a separate piece, or just cut out a wide enough section for the radiator to clear out of the original? I can see the weld beads where you boxed in the open part where it was cut, I just can't make out if it goes all the way across.
Welding the "shroud" to the top of the radiator was a pretty slick idea.
Good job, looks very professional ! What kind of money did all the equipment cost for this project ?
Man, that's cool!! Heck... I'm impressed enough with how much space you've freed up. There should easily be enough room for something like a turbo kit. Great work!
that's a kick *** setup
Here is a pic of my a Fully ported GM LT4 intake from GTP that I traded for my single plane. You can look how it compares to the Edelbrock, I really like the way the Edelbrock is looking, a lot of Potential from this intake.
Originally Posted by T/A KID
thought about powdercoating black????
