track tires
Old 10-01-2007, 12:14 PM
1slowZinthe513's Avatar
Default track tires
alright guys if you could help Id like suggestions on what type/brand/size tires to get for the track. Now I have plenty of spare salad shooters to mount tires on but I'm kinda wanting to get some cheap 15 inch lightweight wider steel rims to mount these on. I would like to go as wide as I can without anything touching back there.
So like said.. What brand and sizes of both the tires and rims.. links would be AWESOME if you have time.. I dont care if these tires are street legal or not for they will only be drivin to the track and back
Old 10-01-2007, 12:48 PM
speed_demon24's Avatar
M/T drag radials should be fine at your power level. And height is more important than width for traction.
Old 10-01-2007, 12:50 PM
dhdenney's Avatar
I do well on 26X11.5 M/T ET Streets. My best 60' is a 1.53 on stock shocks and springs.
Old 10-01-2007, 02:51 PM
i didnt know height was more important
whats the difference in the setup between ET streets and drag radials and whats the cost difference
also what size rim would you guys go with.. i really dont want to put them on the ugly salad shooters
Old 10-01-2007, 03:18 PM
Default M/T ET Drags 30x10.5Sx15
https://ls1tech.com/forums/showthrea...T+drag+radials
would these be a good set for me?
Old 10-01-2007, 08:19 PM
dhdenney's Avatar
I would think they would have a hard time cramming a 30 inch tire under there.
Old 10-02-2007, 10:35 AM
what size would you recomend
Old 10-02-2007, 10:38 AM
dhdenney's Avatar
Mine are 26" tall. I think a lot of guys run the 28"s. What gear are you running out back?
Old 10-02-2007, 10:53 AM
I was TOLD from the previous owner that im running 373 gears but he lied to me about a few other things so i dont know how true that is and i havnt gotten around to check either.. but its either the factory 342 or the 373.. i know its not 273
Old 10-02-2007, 11:12 AM
dhdenney's Avatar
With 3.42s or 3.73s, I think I'd just stick with 26"s but that's just me. Some might say the traction would be better with the 28"s but I was looking at the overall effective gear ratio. See a taller tire will decrease your revs and I don't think you want to do that with your gear and cam. Which brings another question, what is your cam?
Old 10-02-2007, 11:18 AM
http://i121.photobucket.com/albums/o...per513/cam.jpg
Old 10-02-2007, 12:11 PM
dhdenney's Avatar
Yeah I wouldn't go with a 28" tire if it were me. You'll want to keep your revs up, especially if you have a 3.42 gear. I was trying to think what my setup did with 3.42's when I was still M6........... Are you doing about 1500 RPM at 60 MPH in 6th or more like 1900?
Old 10-02-2007, 03:10 PM
couldn't tell ya.. my speedometer hasnt worked since i had the t56 put in.. (bad speed sensor) and i have been too lazy to get a new one
alright i guess ill go with 26 in tires..
is there a way i can ADD a poll to this thread.. id like to if people think i should go with et streets or drag radials since they are they same price..
Old 10-02-2007, 03:24 PM
dhdenney's Avatar
I've seen some good 60' times with drag radials. A plus is you can drive to the track with them on.
Old 10-02-2007, 03:50 PM
see thats what i thought. but when i called summit today the guy told me that the drag radials are not street legal.. i told him i was just wanting to take them to and from the track.. he said do not run them on the street because they will pick up eveything on the road
i have one more question to sum this up.. will 15x10 wheels clear my calipers fine or would i have to grind them.. and or is it worth it to grind them or should i just put these tires on some salad shooters
Old 10-02-2007, 04:04 PM
kinglt-1's Avatar
Get the m&h racemaster 28" tall DR's and put 4.10's in it. You will rape through the quarter! This is what im going to do! The 28's should drop me down to a 3.90 final drive or close to it.
Old 10-02-2007, 04:08 PM
DopdBrd's Avatar
I run 15x10 Prostars with 275/50R15 Mickey Thompson Drag Radials for the track.
If you run a 15" wheel, yes you will have to grind down the rear calipers. DO NOT run spacers on the rear due to the high torque load.
The 275/50 is a 26" tall tire and honestly I would go with those. The only reason I would switch to a 28" tall tire is if you were running something like a 4.10 gear in the rear with nitrous.
A 28" tall tire on 4.10's will actually make them feel like 3.70's I believe. If you run a 28" tall tire on a 3.42 car it makes it feel slower. I ran some 325/50 on the car when I first got the rims and it bogged way too bad off the line.
Old 10-02-2007, 04:26 PM
kinglt-1's Avatar
Ok 3.70 would be perfect woth some spray, I lovet it. I agree do not put 28's on stock gear. Im currently running 25.6 on 3.42's and want more gear and traction, so I thought 28" with 4.10 w/ spray would be a good combo.
Old 10-02-2007, 05:12 PM
DopdBrd's Avatar
28" with 4.10s and spray would be a GREAT combo. I plan on running that when I get a 12 bolt with 4.10's.
Old 10-02-2007, 08:12 PM
how much grinding will have to be done on the calipers and will it affect the quality of braking
Quick Reply: track tires
