lt1 oil pump question
i have primed the system and put the oil shaft thing that the cam turns to turn the pump it went in easy but is there a way i can make sure the cam is turning the pump before i put the intake on?
Well sounds like the pan is on the car. That's pretty much the only way I can think of, turn the crank and watch the pump. In my experience. The thing just falls right in there. If it won't go in, turn the crank just a hair and it will fall into place. I've never heard of anyone putting it in and not engaging the gears.
