Vacuum Leak
Vacuum Leak
So after my idle was screwy last week I noticed it sounding really airy and hissy so I think I have a vacuum leak. I opened the hood to see if I would find any hoses that were loose or off and I didn't see any but the sound seems to be coming from the drivers side of the intake manifold around halfway back or a little farther. It's coming from that general area. My idle and everything seems fine now but it still sounds like I have a vacuum leak. Any idea what could be off
That last 1s noise is just your motor acting normal and you hear it because of the CAI/RAM Air. Or so I think at least I don't have any problems and mine does that as well.
1 Post
if you really want to find out if its leaking... spray carb cleaner around the area you think is leaking... if the car bucks or surges, then you've got a leak in that area
Use Carb Cleaner, it works best 2 fold: It evaps quick, so no mess, and it's highly flammable, so that's why it causes the rev up. The WD40 probably wouldn't cut it. Brake cleaner might, but it's a lil caustic to plastic/rubber.
