Replacing connecting rods on LT1 by myself
So I have experience in replacing motors, but only on an import (93 240sx). I've also replaced clutches and transmissions. I've recently found out I need a new connecting rod, because the one in the motor now is bouncing around making a loud knock. I think this was caused by not having oil in the motor, because somehow it all burnt up, maybe from a piston ring going out I was told.
I haven't driven it since it started, and only drove it for 2 miles after it started making the knocking noise. But I have started it up once for about 20 seconds to show a guy that work's with LT1's what it sounded like so he could diagnose it.
I ordered a haynes manual so I could pull the motor through the hood in a friends garage, and then have someone with the right tools replace the connecting rods themselves in a shop. Or maybe I can do it myself? I'm borrowing a cherry picker and other tools from a friend to do remove the motor. The price I was quoted for the work if they did EVERYTHING was over $3,000, and I have about 200 in my pocket right now. So I have to do as much as I can on my own.
My question is, what exactly should I expect on my 93 Z28? Like I said, I've replaced a motor before, and it was probably more complex considering I had to frankenstein it from a OBD II to OBD I and it had about 99999 sensors. I've heard of guys doing this on the concrete, so I shouldn't have a problem in a garage with some good tools. I had oil up to it's level about a month prior to it all disappearing, is there anything I should replace in the motor while I have it out? Someone said this site is the best when it comes to fbodies,so I hope I can figure this out and get some good pointers. Thanks everyone.
I believe your problem is a rod bearing not a rod.
If you ran it w/o oil, at the minimum you should check all of the bearings (rods and mains) and your cylinder bores too.
Rebuilding the LT1 is the same as rebuilding any SBC, its going to be the OH buy the ways and might as wells that will blow your budget.
Good luck.
Mike
Good luck.
Mike
In-Zane Moderator
Man, i ran a dodge 318 with no bearing(it spun and chewed it up) and was bouncing off the rev limiter not caring. After tear down for rebuild i had to replace the crank, but...the ******* rod was still good!! I only had to resize it! It is not hard to do though, if it just started nocking i bet you are in good shape, prolly just replace the bearings, have the rods checked, have the crank turned, hone the cylinders, throw he back together with some port work on the heads and a little cam, you will be happier than ever. Good luck!
If knocking there is a good chnce the crank needs at least a polish.
The rods are pressed to the piston pins so no way you can seperate them safely at home.
If you think dropping a OBD2 motor into a 93 required "frankenseining" then this is going to go badly as VERY minimal changes should have been required to put a 96-7 motor in so if you thought it rquired any creativity you did something wrong.
Originally Posted by vtec
pull the motor. dont go through all that just to find a chewed up crankshaft and need to pull the motor anyways.
Originally Posted by infinitebird
You would be much better off ordering a helms service manual for your year.
Thanks for the input everyone.
