Reccomended Oil Pump, Pan, Filter?
Well, its getting cold outside and in dec i plan on puting a new oil pan in the car. Along with a High flow oil pump. I had a new pump come with the car, but have since misplaced it. I hear canton is really good and so is moroso. Any suggestions guys? Im not wanting to drop a lot, kinda on a budget being a college kid.
Also, can the oil pan be replaced without needing to jack the motor up off its mounts?
P.S: Any 350 oil pan will fit right?
You need an LT1 specific oil pan. I recommend Canton. Also you can use your stock oil pump, just get the high pressure relief (white) spring that bumps up the pressure. GM "white" spring p/n: 3848911.
P
P
X2 for Canton. I have a Canton 7qt. stroker/kick out pan with the Canton High volume oil pump and pickup tube to match. The whole set was 400 but I like it ALOT and it looks ****** sick.
