Comp Cams XFI 260 HR13
Old 11-08-2007, 03:23 PM
onephatZ28's Avatar
Default Comp Cams XFI 260 HR13
Anyone have this cam in there car, or now any one running this cam, if you do what power did you make?
THANKS
Intake Duration at 050 inch Lift: 210
Exhaust Duration at 050 inch Lift: 218
Duration at 050 inch Lift: 210 int./218 exh.
Advertised Intake Duration: 260
Advertised Exhaust Duration: 270
Advertised Duration: 260 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.560 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.550 in.
Valve Lift with Factory Rocker Arm Ratio: 0.560 int./0.550 exh. lift
Lobe Separation (degrees): 113
Old 11-09-2007, 03:27 AM
onephatZ28's Avatar
Anyone?????
Old 11-10-2007, 02:28 PM
onephatZ28's Avatar
no one has used is cam?
Old 11-13-2007, 03:19 PM
onephatZ28's Avatar
Ttt.....
Old 11-13-2007, 03:30 PM
96LT1355Z28's Avatar
Default Comp Cam
I've got that cam. It sounds great and makes alot of mid to top end power. I had my car on the dyno but learned it had two dead cylinders. 303 rwhp/ 292 rwtq it made 288 rwhp and 309 rwtq stock I replaced the optispark, plugs, and wires and it runs much stronger. I have another dyno appointment on Friday. I'll post the results this weekend.
Old 11-13-2007, 04:26 PM
onephatZ28's Avatar
Kick ***, LET ME know how it works Thank for your time
GOOD LUCK WITH YOUR CAR
Old 11-14-2007, 09:21 AM
Vicious95Z28's Avatar
It's prolly a great lil cam but most guys won't fool with it because it's pretty small. Most larger cams work really well with the LT1 AND CAN BE TUNED TO BE VERY DRIVEABLE
Old 11-14-2007, 12:56 PM
onephatZ28's Avatar
Ya, I know I did noy want a big cam in my Z28, that is why I got my Nova
I just did not want the car to scream hay everyone I have a cam.
were I live they do "random" smogs on the street. I had to to it 2 times now
and it sucks, thank god I was in the wifes car.
Old 11-14-2007, 01:47 PM
Internet Mechanic
BlackScreaminMachine's Avatar
You can run a hotcam and pass CA emissions which is bigger in the duration and LSA catagory, thats where the power is made.
Old 11-14-2007, 05:33 PM
96capricemgr's Avatar
The HOT cam is a tighter LSA and ALL the off the shelf stuff is in a wide LSA for drivability and emmissions reasons and it hurts power.
Old 11-14-2007, 05:53 PM
Default Cam
onephatz28, Hey sorry man I looked at my cam card and I have the Comp 280XFI HR-13 not the 260. I'll still post my dyno results but it looks like the 280 is a bigger cam.
Old 11-14-2007, 09:59 PM
onephatZ28's Avatar
^^^^thanks man. still let me know how you do.
GOOD LUCK
Old 11-14-2007, 10:03 PM
onephatZ28's Avatar
I know there are better cams out there, I just wanted to see if anyone was running this cam.
Old 11-18-2007, 02:35 AM
onephatZ28's Avatar
ttt......
Old 11-18-2007, 11:46 PM
Default Cam
I made 371 rwhp and 351 rwtq at the dyno on Friday. It went 12.59 @ 112 mph with a 1.9 60 foot today (26X11.5 MT ET Streets). I broke some teeth on my ring and pinion on my third pass The car has ported heads and intake a 52 mm throtle body, electric water pump, long tube headers, and all the other normal bolt ons. Hope this helps.
Quick Reply: Comp Cams XFI 260 HR13
