Price for LT1??
Price for LT1??
i bought a gutted out 94 Camaro, (it was a race car project from buddy).
i went to a local salvage yard to find a drivetrain for the car,
they have a 95 Z28(car was rearened and demolished the frame) the motor has 63,000miles on it. they started the car for me, it started right up and ran great. they gave me a price of $1400.00 for the motor, transmission, wiring harness and ecm
is this a reasonable price???
thanks in advance
thanks in advance
Offer them 1200. Part out the remainder of the car, hood, fenders, windshield, front fascia. I know of a shitload of f-bods that involved rear-ending someone else. I'm sure good front-end metal would sell pretty quick for you.
If you're building a race only car don't even buy the tranny. You will end up buying a converter to get it to run decent, then you'll have to replace it when you change over to a TH350 or 400.
Or rebuild the 4l60e stronger, thats what Im going to do. The 4l60e can be strong if built right.
Sorry, but if it's a race only set up, you guys are spending extra money to go slower. The 60E is heavier and harder to turn than a TH350 plus the gear spacing sucks. The only reason for staying with a 60E is for the overdrive. The OP specified that he was building a STRICTLY DRAG RACING set up. Why would he want an overdrive?
I'm not familiar any drag car wire kits. Are they LT1 specific? If not, I suspect that you will need the factory harness. You can modify it to take out all the stuff that you won't be needing.
But this is all about money.
I am sure of you could afford a crate LS 364 or LS2 you would go that route.
If youre going all out LT1, switch to a distributor and get that 10bolt out of there. Sell the 4-L60E and put the money towards a TH350/TH400.
