engine sounds
No but there is an A/C delete pulley at most aftermarket retailers. I had to use one until I got enough money for new A/C compressor. The A/C delete pulleys are around 40 dollars and easy to put in. Remove A/C compressor, install delete pulley and put the belt on,...Done!!
Yeah, but as soon as it locks up, or breaks the hub off of it your belt is gone and you are stuck on the side of the road. Like nychucky said if you don't want to drop 300 on a compressor then spend the 40 on the a/c delete pulley.. Just good insurance..
