'95 B-body LT-1 in a '94 F-body
Old 11-14-2007, 04:18 PM
94 F-body's Avatar
Default '95 B-body LT-1 in a '94 F-body
I was wondering if there is any diffrance in the crank pully bolt or the spacer to the crank pully bolt, I know that the accessories bracket and crank pully is not the same, so is the crank bolt / bolt spacer differ ? The local dealer says that all LT-1's have the same crank bolt and spacer, but I have reason to think other wise.
Old 11-14-2007, 05:19 PM
Scrapin'4.8's Avatar
Different hubs i believe. I have an F-body hub on my b-body car and it causes the belt to be off by about 3/8 an inch.
Old 11-14-2007, 06:47 PM
94 F-body's Avatar
thanks, but I want to know if the bolt and or the spacer is diffrent, I know about the other things you are talking about
Old 11-15-2007, 03:08 PM
Oh, well i guess i was just throwing out words then, lol. I'm pretty sure the bolt and stuff is going to be the same though.
Old 11-15-2007, 11:54 PM
Biggin'89's Avatar
i've never heard this, what is different about the hubs?
Old 11-16-2007, 12:19 AM
94 F-body's Avatar
it is the part of the hub that bolts to the crank has a diffrent spacing for the diffrent bodies, one space for "Y" and "F" bodies and another for the "B" bodies. I made shure to use the crank pully from my old motor but now I am wondering "WTF" is going on.
Old 11-16-2007, 08:40 AM
SAPPER's Avatar
From my experience. the only one that is different is the LT4 hub. All B & F LT1 are the same. If your hub is off by 3/8" then something is wrong.
The difference between the LT1 - LT4 hubs are very noticable, the snouts are different diameters.
Don't quote me on this but I have a F-body hub on my 94 Impala SS and there's no issues.
Old 11-16-2007, 08:48 AM
Biggin'89's Avatar
ok b/c i am building a lt1 out of a roadmaster and was just going to use the hub, not knowing it was different.
So Sapper you think the roadmaster and f-body hubs are the same? or atleast will work w/o problem?
Old 11-16-2007, 09:25 AM
SAPPER's Avatar
I work on many of the 2 and never seen a difference except for an LT4 hub. But maybe some else will chime in if they had seen different.
Old 11-16-2007, 12:09 PM
makWS6's Avatar
B-body Hubs Are Longer. If You Go To Buy A New Keyed One There Are 3 Different Lengths For Lt1's. When I Bought My Impala Ss It Had A F-body Hub On It And The Belt Was Overhanging The Balancer.
Old 11-16-2007, 03:01 PM
94 F-body's Avatar
all I know is that the "so called" B body motor that I bought I had to change the water pump and crank pully to get it to work in my F body. I had two buddys that were there when I realized it and they agreed that the pully is not the same.
Old 11-16-2007, 09:47 PM
Biggin'89's Avatar
well after reading this website: http://www.automotiverebuilder.com/ar/ar99928.htm i really don't think there is a difference between the f-body/b-body hub. i think the problem is that the correct key isn't being used. but what do i know
Old 11-20-2007, 02:05 AM
94 F-body's Avatar
F.Y.I. to all there is a diffrence in the balancers and the Gen II LT-1 motors are not keyed, the Gen I are, I know from experence.
94 F-body's Avatar
