custom grind
custom grind
i was thinking about getting a custom grind cam with the same specs as the MS4 for the ls1 instead of the CC306. does anyone run anything close to it in their LT1?
here is the MS4 specs so you guys dont have to search.
239/242 .649/.609 112 lsa
1 Post
I agree the valve events need to be rearranged but, the actual duration,lsa is doable.I say tone the intake lift down about .040.I whould not run stock heads with it.Maybe go with a nice set of 2.00 1.60 valves and a expericed port job.Sounds like a good R&D project if you got the money.I would be interested if you did actually grind the same cam for sb2 just not recommended.
1 Post
I just thought of somthing can anyone confirm the gm hot cams valve events for ls1 & lt1.Are they the same?They seem to boost performance in the same manner on each motor from the cars that i have seen.Just curious about which car responded better and why.Not trying to get off subject but i would like some sort of proof in our theories.
And one more thing to think about is the LSx intake manifold helps mask the over cammed cars and keeps the RPM's around 7K max with the plastic intakes. That cam in our cars would probably want to rev 7500+ rpm's... And your car would be an absolute pig below 4500 RPM's with that cam. Just get a custom cam to suit your needs instead of the bigger is better mentality.
this was just an idea i was thinking of this morning.
Sounds like you want a big cam to boost your ego, in that case this is pretty much the biggest off the shelf cam made for LT1's.
http://www.cranecams.com/?show=brows...tType=camshaft
240/244 .595/.595 on a 110 lsa....
