OBD1 to OBD2 conversion
Old 11-22-2007, 12:55 PM
Hybrid86Z's Avatar
Default OBD1 to OBD2 conversion
whats all needed to do this? new computer and sensors? would i need to re-do the entire engine sensor wiring too?
I don't have crap for GOOD OBD1 tuners in my area, all have gotten into the LS1 tuning w/ the OBD2 stuff, I'd like to be able to use them to tune the car.
Any help is appriciated.
-Ben
Hybrid86Z is offline
Old 11-22-2007, 01:00 PM
ckyconan2003's Avatar
OBD1 PCM and 93-95 knocksensor
ckyconan2003 is offline
Old 11-22-2007, 01:05 PM
Hybrid86Z's Avatar
i'm converting FROM an OBD1 setup TO an OBD2
so just an tuned OBD2 computer and an OBD2 knock sensor is all i need? thats what i'm hearing.
Old 11-22-2007, 07:06 PM
96lt1m6's Avatar
you are correct.
OBDII pcm tuned for your conversion, a knock sensor.
96lt1m6 is offline
Old 11-30-2007, 07:23 PM
YORK_MUSTAINE's Avatar
Originally Posted by 96lt1m6
you are correct.
so just the knock sensor and a obd2 pcm?
YORK_MUSTAINE is offline
Old 11-30-2007, 07:33 PM
Hybrid86Z's Avatar
thats what he said I'll let you know how it goes if i decide to give it a try.
Old 11-30-2007, 07:37 PM
96lt1m6's Avatar
yes.you do plan on getting a tune aren't you?
you need to have the CPS,rear O2's deleted from the OBDII pcm
96lt1m6 is offline
Old 11-30-2007, 08:59 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Ain't there a crank sensor on the OBDII?
Paul Bell is offline
Old 11-30-2007, 10:39 PM
Transamthunder85's Avatar
CPS? Actually this good info, I have the same prob. My buddy has HP tuners and we werent able to do anything with it because mine is a 95 also. So the wiring harness or nothing else needs replaced?
Transamthunder85 is offline
Old 11-30-2007, 11:05 PM
96lt1m6's Avatar
yes,it needs to be deleted from pcm
its mainly for emission
Crank Position Sensor
nope,no harness mods. you cannot use HP on these cars
Last edited by 96lt1m6; 11-30-2007 at 11:16 PM. Reason: my computer shut off (lightning out)
96lt1m6 is offline
Old 11-30-2007, 11:09 PM
1bdbrd's Avatar
Hp Tuners WILL NOT work with an LT1 pcm. A swap to OBDII won't help you really at all.
1bdbrd is online now
Old 12-01-2007, 12:43 AM
TwoFast4Lv's Avatar
BTW no one has mentioned the other wire you need to run from the Passenger kick panel to the ALDL
TwoFast4Lv is offline
Old 12-01-2007, 07:44 AM
bricez28's Avatar
is there a scanner for obd1 that doesnt need a cigarette lighter? i was trying to scan and we had some fancy scanner that needed a cig lighter.
bricez28 is offline
Old 12-01-2007, 02:43 PM
1bdbrd's Avatar
I use freescan on my laptop for my 94. I will be switching to Datamaster though. It still needs a cig. lighter if your laptop battery isn't very good.
Old 03-19-2010, 12:01 PM
stburgpete's Avatar
Sounds like fun.
stburgpete is offline
Old 03-20-2010, 06:21 AM
S10Wildside's Avatar
As far as I know you can only tune an OBDII LT1 PCM with TunerCat OBDII...which was sold to JET. So unless you can find someone with TunerCat OBDII the other option is to buy JET's software.
I talk with a lot of LT1 guys and finding a tuner who wants to touch an LT1 car is not easy these days.
S10Wildside is offline
Old 03-20-2010, 06:41 AM
gregrob's Avatar
Jet DST and LT1 Edit are your only two options for tuning OBD-II LT1's right now...
gregrob is offline
Old 03-20-2010, 06:42 AM
gregrob's Avatar
You need to check out Tunerpro RT V5 Beta. It works with LT1's now and has built in data logging. Much better than free scan, fully customizable. You can actually make it show more data than datamaster. No way am I paying for datamaster now that I have this.
gregrob is offline
Old 03-20-2010, 09:28 AM
MasterTomos's Avatar
wow...thread dug up from '07... at least people are using the search bar nowadays!
MasterTomos is offline
Old 07-18-2010, 05:00 PM
alexcoreas's Avatar
Yup we sure are. I have a 95 and it has an obd2 , which is better for tuning? I hear obd1 and others say obd2?
alexcoreas is offline
Quick Reply: OBD1 to OBD2 conversion
