Found the problem now I need to know part name..
So my car started leaking coolant today, luckily it was a visible and easy to reach spot, I pulled out this broken piece
the piece is located right after a bleeder screw and the line that it connects starts at the front the engine right where the intake connects the manifold
If somebody knows the name of this piece that would be great so I can pick it up at work tomorrow, thanks
well since it was probaly spliced in the hose w/ the bleader screw ur talking about. That hose has metal crimps so its kinda of hard to replace with bulk hose. I would just go to a parts store and get a splice and use it. Its just a plastic piece with two barbs on each end that eill combine both ends, just use the same clamps and ull be good to go.
wow, so I bought a new kit (only like 5 bucks) and put the new piece in, it all worked fine until I see it leaking again, now the cap on the new one is leaking! wtf?? I hate these things..
