let's hear your custom LT1 cams!!!
Heres mine
http://uk.youtube.com/watch?v=1vNTWz4yvF8
254/254@.050 .678/.648 108LSA
The vid is with the car idling at 1200 rpm
Makes 463 rwhp through a 4L60E, a 9 inch rear and FULL ex and pump gas.
David
David
Guest
Posts: n/a
http://youtube.com/watch?v=06B7mhgE8rg
Lazer cams custom hydraulic roller
11.3@119 NA
10.4@130 150 shot
11.3@119 NA
10.4@130 150 shot
I need to find the card but here's what I remember.
240/245 112 lsa, made a whopping 400 on the dyno. ET for the NA run was 11.5 @115, 100 shot got me 10.42 @ 126.77. I think you should specify if you mean stock CI , plus combo on ET's can be different that Dyno #'s would. 6 spd or A4? All make the #'s different!
http://www.youtube.com/watch?v=vMH_8Q1Md5Y
this is great I want to hear all types of CI lt1s and different setups just let me know what isn't stock(CI, heads, etc.). hell even some forced induction motors would be cool to hear although i was originally talking about n/a. thanks and keep em coming
This thread may create some controversy with folks posting specs, but I'll do it in the name of the hobby!
First the motor is a 383 with LPE/E.B. Bradby ported LT1 castings, 2.00/1.56s valves...
Cam is 226/234 .568"/.568" on a 111 lsa
Car is an A4 with 4.10s and (at the time of the track runs) a Vig 3600...Stock ported intake with 58 mm TB...
Times/mph/ in my sig...raceweight is 3600...
--Alan
--Alan
Solid roller 396, LT1 ported heads, T&D shaft mount 1.55 RR
254/260 .63x/63x 112lsa custom grind
View Video on FQuick
Here's my LE2 cammed LT1 w/stock heads for now. Put down 347hp/326tq to the wheels, and trapped 109MPH both with a lot of problems(tranny/valvetrain). A friends bolt on LS1 that put down very similar #'s ran 12.0x@110mph, so Im shooting for 11's once I get a good tranny, tuning, fuel system, and some sticky tires.
http://s121.photobucket.com/albums/o...t=MOV00298.flv
264/271 .688/.660 108lsa 1.6 rockers also
only makes 451 rwhp and 366 rwtq and it went 10.73@127 the first time out with it(near full weight 3450 lbs)
with some weight reduction and a better 60ft and some more tunning I think it will go 10.30`s
I was trying to find a good current video, but none apparently exist...Here's a thread from a rental last year before suspension, TDs, spool, 4.10s,and bigger DRs....Still sounds cool though...
https://ls1tech.com/forums/drag-racing-results/601779-11-36-119-75-n-383-lt1-vids.html
--Alan
--Alan
The hood is a bolt-on VFN 2" cowl fiberglass, weighs about 19 lbs.
Here is the vid of last time I was at the strip with clutch slip galore: View Video on FQuick
Next time out hoping for a 10sec pass on motor, clutch is fixed, and have a chromoly drive shaft in the car now, so it is ready for a 7k RPM launch.
P
