ls1 springs for the smaller cam guys?
Can you use stock ls1 springs on lt1s with smaller cams? They are a beehive spring but i dont know what lift they are good up to. As in the guys runnin a 503 cam, can you run these springs or are they still a small spring. Only asking is because i have a set of springs from my buddys car layin around and if they do work then i can sell um for cheap to someone here. Or at least a upgraded spring if someone is only doing 1.6 rockers and not a cam.
