Anyone Dyno Gains to a ported stock intake manifold on a bolton car?
Just wondering if anyone has put a ported on a bolton car, thinking about getting one...
Ive searched and havent found alot of info on this
I wouldn't think there would be any noticeable gains from this. You can't open up the runners that much if at all because you still have stock ports on your head. If you do open them up then you get reversion and turbulance from the air hitting the face of the head.
I dont see how a LT1 is any different when our intakes are not that great to begain with,,
Im just looking to see what the gains really are
Um in the other threads people are saying not to gasket match or mess witht he lower end of the intake manifold
Im talking about how LE ports it, not some hack job in his backyard
Real world numbers, from a ported LE and is anyone using it and seeing gains and what exactly is ported on them
That doesnt make alot of sense because 5.0 mustangs,2vs,LS1s, even hondas see gains from better flowing intake manifolds with boltons..
Jordon Musser ported my intake and on my H/C full bolt on car I saw around 8 rwhp. If you don't open up the heads to match then it's pointless. You can port the whole intake manifold and leave the port exit the same and that would be pointless as well because only a certain amount of air can flow through an opening and unless that opening is enlarged then there is no point.
This should settle this argument quoted from Lloyd Elliot
"Most people do not see gains from a ported intake for two reasons.
1 - the heads and cam used are not sucking on the intake hard enough to show much of a gain.
2 - most ported intakes have very little done and is just "gasket matched". There is ALOT more to porting an intake and gasket matching is the wrong thing to do anyway.
The more radical the set up (bigger cubes, more compression, bigger cam, more RPM, etc) and the more free flowing parts you have (LS1 air lid, 58 MM TB or mono blade, 1 3/4 or 1 7/8 headers, 3" true duals, etc, etc) the more the stock intake will restrict power and the more the WELL ported intake will show some gain."
Lloyd
So, let's ask the question of how hard is a fairly stock engine going to "suck" on the intake?
Lloyd
What Lloyd said makes perfect sense. On a stock LT1 motor the intake manifold is not the restriction. You have bigger fish to fry with the other parts mentioned. First of all I would start with the exhaust if you have not done so already.
