95 LT1 to LS1 Coil conversion
Im looking for a place to buy a lt1 to ls1 coil conversion kit for a 95 T/A dont feel like messing with the distributor behind the water pump anymore, any places that sell them? Ive looked but no luck
youre gonna need to re work the PCM completely for the ignition add a crank trigger/position sensor, get the coils, make a harness, get some crack ****** to smack when you get stressed out, and you ned ALOT of time.
LTCC would be much easier.
http://delteq.com/
Edit: I do not endorse or own the product mentioned in the URL above. I have limited knowledge of how well it works, longevity, and performance.
To all who were no help
Well i paid $125 to have my computer in my 99 T/A programed has auto tranny so my shift time is a whole hell of a lot faster, with everything else he programed it gave me 20 extra horse from a stock ls1, in that process i told him i had a 95 T/A and i wondering if i could do a coil swap like the one in my 99 he said that you can and he sure knows a **** load of info about lt's and LS's owning a 98 T/A and 94 camaro and 2002 corvette himself doing all his own work, so if you think it cant be done then you dont have to put your input of how is cant be done, IF YOU READ THE THREAD "Where do i go about finding a coil conversion kit" NOT CAN IT BE DONE!!!!!!!!!!!!!
dont get mad at them for saying any thing, their just trying to tell you a easier option, and what would need to be done, and just cause this guy thinks he can do it doesn't mean he can but who knows, maaybe you guys can come up with some thing that could help every one else out alot..
This is a great plug-n-play kit, it's worked flawlessly for me and eliminates the problem area of the Opti-spark system:
http://www.bailey-eng.com/
Just something to consider as well.
It is possible. This is what you would need. FAST XIM and XFI boxes, MSD crank sensor, cam sensor, coils, lots of patience and time. It is expensive to do though. I just got mine up and going. Runs good so far. Its a pretty neat setup. If you want more info you can PM about it and I can give you the contact info for the guy who puts these kits together.
That's MISTER MODERATOR
94transamTOM:
The issues with the GM Optispark are that the high voltage goes through it and it’s location on the engine, under the water pump. The optical pick up is highly accurate and still used by some other makers. The LT1 engine PCM must have this particular optical pickup as it needs sensing for low and high resolution. The LTCC and DELTEC kits moves the high voltage out to coil packs. The LTCC uses LSx type coils like you mentioned. The DELTEC kit uses four shared coils. The LTCC costs more that the DELTEC. They both work well.
I’ve converted to the LTCC kit. Better plug wiring and no cap/rotor to rely on. Any performance improvements are minor but I’ll swear that my car ran smoother when I did the swap.
Here’s a link to my install:
https://ls1tech.com/forums/lt1-lt4-modifications/651634-ltcc.html
Good luck!
Good luck!
Seriously, if the guy says it can be done, get that informtation from him, prove it yourself on your own vehicle, documenting the whole way. Then share it with us here, and you'll become a hero on the board.
Paul Bell stated the well known facts about the LT-1 Opti-spark system and people who have choosen the LTCC or Delteq system have had great success. Everyone who responded to your initial question was trying to tell you that there is no known "conversion kit". If your tuner has a way of converting an LT-1 ignition system to an LSx based system, then he should be able to provide you with the "kit". If he knows something that the rest of us don't, then either he should post the information here or you should have the conversion done and you post the information here. Either of you would be heros!!!
Ok, I wasn't planing on registering, but since there are idiots here that think they know what they are talking about, I had to get registerd.
Like it was said above, http://www.bailey-eng.com/ is a piggy back so you can run the LS coils. Yes it does work I know people with them and it works perfect. Also, Delteq is another company that you can use, but insted of the ls coils it uses the northstar coil pack, which I use personaly, also no problem with it. Yes, you do need your distributor for your cam sensor, but its a whole lot more reliable, especially for them high rpm's. I have seen both on stock cars, and highly modified (like my car).
I agree, If you don't have something constructive to say, only dumb comments, don't say anything at all.
I'm not saying that the opti is bad, because myine went for over 105k. Then i went through a bad t-storm and the way I had my air filter water went in the opti and burned it. Thats why I changed it over, you have spark with water = boom. No, it does not cost thousands to do the swaps. I did mine for 450.00 (delteq). I can not remember about the ls coil convertion, but that can cost you about 650.00- 750.00. If you buy the coils used from a wrecked car even cheaper.
Yes, it is possible and for under 1k.
