Gauge wiring
Gauge wiring
Ok i just got a Autometer electric oil pressure gauge along with a Autometer electric water temperature gauge and i know where to get my power and the ground but what wires do i tap into get my readings for the gauges signal?
AllData says that the oil sender has 90 ohms at high pressure and 10 ohms at low pressure.
The oil pressure wire should be tan. You'll have to find it underneath your dash... You could test to make sure of which one it is by momentarily grounding it, with the car on. This should make the factory gauge jump.
For the coolant -- AllData says 1365 ohms at 100 degrees F and 55 ohms at 260 degrees F.
This one is a dark green wire. Routing should be similar. Use same momentary ground method to double check.
Hope this helps...
I seem to recall installing at least one that had jumpers on the back for various senders...
There are also Autometer gauges that are matched to the OEM senders. I couldn't find any links, but I've seen them before.
