Pinion Angle and Bolts
Ok so I bought a body mounted torque arm from UMI w/ a magnetic angle finder. What should I set my pinion angle at? Also I didn't buy the hardware kit for an aftermarket torque arm. I kinda forgot and I need to get this on as soon as it gets here and I know I need 9/16" size but what length and stuff?
pinion angle @ -2 degrees. i would just pay for overnight shipping on the hardware for the torque arm bolts, dont wanna half *** those bad boys. it will be tough to find ones that long at a local hardware store.
you dont want to half *** it, i broke a torque arm bolt already and tried to find a lowes replacement, couldnt find anything. it may seem expensive, but you get what you pay for.
That's MISTER MODERATOR
These are very special bolts. You won't find them. You'll need to get them from UMI. All the guys that make TA's offer these bolts, they're specially made for this application. Length, size and grade. Even if you found a hardware bolt in the size, you'll break it.
