Anyone swap there Kmember out with the motor in the car???
Old 01-13-2008, 12:52 PM
matt94z's Avatar
Default Anyone swap there Kmember out with the motor in the car???
Getting ready to swap in my BMR K member. How did you support the motor? I don't want to leave all that weight on my $300 oil pan and take a chance of denting/crushing or have it leak.
Old 01-13-2008, 01:10 PM
grn95t/a's Avatar
used a 2x6 piece of wood on a tripod on the damper to hold the motor when i did mine. did mine on a lift. so u could use a jack instead if your on the ground.
Old 01-13-2008, 01:22 PM
matt94z's Avatar
Thanks man. That's what one of my friends said to do.
Old 01-13-2008, 02:25 PM
joelster's Avatar
A chain off of a strut tower brace will work also.
Old 01-13-2008, 03:21 PM
wannaB tuner's Avatar
I used a metal square tube that rests on the strut tower and I wrapped chain around tube in line with holes in the head and then bolted chain in the holes. That will hold it up so you can remove K-Member.Also it helps to remove motor mount bolts and raise engine a 1/2 inch or so prior to chaining engine to the tube.
Old 01-13-2008, 04:33 PM
matt94z's Avatar
Good ideas guys.
Quick Reply: Anyone swap there Kmember out with the motor in the car???
