88mm turbo LT1
88mm turbo LT1
new to this board just thought I would see if anyone has the same combo and what it should run the car is 97 ss camaro mod list 383 afr 220 heads 530 lift com cam PTK outlaw turbo kit with an 88mm precision turbo turbo400 trans 3600 stall F.A.S.T. efi 9" ford 3.50 gears
pics coming soon weight 3500 psi 20# hoping to get dyno number in the next 2 weeks changed from lt4 intake to single plane car makes about 750 hp to the tires on 13psi now car has full suspension bogarts with 3255015 hoping to make 1000+ at the rear wheels
