Gear Spacer
Old 01-16-2008, 10:17 PM
ROUDA's Avatar
Default Gear Spacer
Ok I going to put 3.42s in the rear end of my car but It has 273s now with a series 2 carrier so I need to get a spacer. I was told that the spacers work loose and arnt a good idea is anyone useing a spacer how do they hold up. thanks.
Old 01-16-2008, 11:21 PM
letsrun97z's Avatar
are you talking about a solid washer insted of the crush washers for the pinion?
Old 01-16-2008, 11:25 PM
zlover129's Avatar
no he's talking about the ring gear, a spacer for the ring gear bolting up to the carrier. If im not mistaken check LS1speed.com, i think they sell Series 2 ring and pinion gears. As far as the spacer, i would try and avoid it.
Old 01-16-2008, 11:26 PM
letsrun97z's Avatar
ah ok
Old 01-16-2008, 11:36 PM
ROUDA's Avatar
yea I no I already have the gears so I want to see if I can make this work.
Old 01-17-2008, 12:14 PM
zlover129's Avatar
you can use it, but like i said i recommend against them, im sure you wont have a problem selling them for close to what a new set would cost that are actually made for your carrier
Old 01-17-2008, 01:13 PM
ROUDA's Avatar
ok I will put them for sale in the forsale section.
Old 01-17-2008, 06:32 PM
ROUDA's Avatar
Is Anyone Using A Gear Spacer.
Quick Reply: Gear Spacer
