Need opinions on 383 build-up
I've been looking at a particular motor build-up and wanted to get your guys opinion on the pricing of the motor build, to see if it's reasonable.
Motor includes: 383 LT1
Block-Baked, Steel Shot, Magnafluxed, Square Decked with BHJ block tru, Bored, Honed with torque plates and jet cleaned. 4 Bolt Splayed Main CapsCrank-Eagle 4340 Forged Steel Internally BalancedRods-Eagle Forged 4340 H - Beam 5.7" Floating Pin Pistons-JE/SRP ForgedRings-Perfect Circle Plasma-MolyBearings-Clevite H - SeriesCore Plugs-Pioneer BrassMain Stud-ARP Main Stud KIt
MELLING M155HV OIL PUMP AND ARP OIL PUMP DRIVE included
I will be substituting the eagle caps for the PROGRAM splayed caps (all 5), upgrading to L19 rod bolts, block will be 1/2 filled. -31cc piston ( I want to get the compression somewhere around 8.7 to 9.1 The engine will come with a complete build sheet of all processes, balanced / blueprinted, MFG defect warranty on workmanship guaranteed to 1000 fwhp.
The motor with said components and machine work was quoted at $3600. It sounded pretty reasonable and the guy was familiar with the LS1 & LT1 community as well as AI & Lloyd Elliot.
Let me know what you guys think of the price and setup. Any recomendations on things you would change or suggest are appreciated.
you would be getting that short block at right around COST considering all 5 billet caps and the machine work involed. The rotating assembly is mid priced but I still calculate that is a steal of a deal.
Karl Ellwein
Karl Ellwein
Well, this is good news. I felt like the price was reasonable, but it sounds like you guys think it's a good price. Any suggestions on other things I might do to the block or components ? I'm hoping this build will be able to take 15 to 18lbs of boost, the setup should be enough to handle the extra stress.
lets see i paid 1500 for a used splayed 396 w a cracked sleeve 300 for a new block 2k for machine work and a steal of a deal lt1 stage 2 gtp heads and 847 cam for 500 that alone is 4,300 now include gaskets fasteners gaskets injectors ect... 3600 for your short block sound great
I just want to be clear on the splayed program caps (all 5). I'm providing the caps at my expense, the shortblock will really cost in the neighborhood of $4100 when you consider about $500 for the program splayed caps. It still sounds like everyone think this is a good deal. The block is included for the price.
