RPM limit for stock bottom end
The LT4 in my C4 exploded last month, and the entire bottom end is trashed. I'm working on putting together a new motor. I dropped my LT4 heads and intake off at Lloyd Elliot's to get fixed/ported. I was planning on freshening up a stock bottom end, and putting my top end on it.
What is the max safe RPM for a stock bottom end? I will have it balanced, with fresh bearings/rings/etc, hopefully with stock pistons/rods. ARP rod bolts and main bolts. The car will be used for road racing/auto-x, and will see extended times of WOT at high rpms. The front straight at my local track (Texas World Speeday) is close to 1/2 mile long, and I will be WOT above 4K rpms the entire time. My heads/cam package will peak about 6300 rpm, so shift at 6400 and rev limiter at 6500.
Is this too high? Anything else I should do to the bottom end to ensure a long and happy life?
I remember talking to Geoff @ Thunder Racing over the phone about my LT1. He said even the stock bottomend is capable of spinning to 7000 rpm if tuned properly.
Right now my shift points are @6500 rpm,limiter set @6900. and still stockbottomend.
So, you shouldn't have any problem w/ your new set up. Good luck.
LE is picking the springs, but he said the springs are well up to the task of the cam he spec'ed, so they should be good. I have no idea how many miles are on the rotating assembly, but the machine shop will check everything out before putting it all back together.
i went on the safe side when i tuned mine and set my shift points at 5800 rpm and the redline at 6000 and that was a bad idea...the setup i have spins through it way too fast and hits the rev limiter before the computer can shift the gear...so i need to bump mine up so i can make full use of the powerband..
I don't see where the tune would have anything to do with the distortion of the rod caps and bearings. Thats what happens when you over rev and stack a bearing. The ARP hardware helps you out a great deal, but you have to keep in mind that the factory clearances are really tight and not much oil coats the bearings sooo.... if you can open them up a bit then I would tend to agree with the additional clearance and the ARP hardware you should be safe to 68-- RPM. That is the max I would ever push a non forged bottom end to, but thats just my .02.
I would suggest installing a set of light weight forged rods. I have had pretty good luck turning the stock rods to high rpm, but have also had them fail due to valvetrain failures. With forged rods I have only had to replace one rod, versus the entire short block.
Good Luck,
Daren
Good Luck,
Daren
If you are getting detonation it will have everything to do with that.
I was referring more at the post stating with a proper tune being able to spin 7k. Aside from detonation issues I stand by what I posted up earlier.
