new Stock LT1 longblock Nitrous et
Went to cecil county md today,pulled about 50 more lbs outta the car,and ran the 175 jets.
First pass,in the heat 95*, but low humidity was a 11.02@124,7.06@98,1.62 60'
Not bad for a STOCK longblock LT1 and a 175 hit in 95° temps.
Later in the night i went a 11.09@122 with about 85-90% humidity,and another 11.02@122 at the end of the night. I couldnt bring myself to run the 200 shot just yet,cooler weather and the car will go 10's as is
Re: new Stock LT1 longblock Nitrous et
he will be fine. i sprayed 200hp a whole year on my old stock shortblock combo that was already making enough power to go 121mph NA in a 3600lb car. 11.5 compression, 92 octane, no timing retard, and it held up fine. just dont do anything stupid and the stock LT1 shortblocks will take quite a bit
did you have aftermarket fuel system. im looking into spraying a big shot, but i will be well over 500 hp on the gas and Im very worried about the fuel system. if you changed yours, what did you change out?
i also forgot to mention the timing/fuel curves etc in the PCM are untouched,i have only corrected for shift/fans/gears/and limited the knock sensor cause of false knock.
Guess it is time for a serious tune in the computer and good weather,with luck it will dump into the 10's.
