Torque arm opinions needed.
Old 02-10-2008, 08:48 PM
donkey mule's Avatar
Default Torque arm opinions needed.
I broke my stock torque arm and was wondering what you guys are using and why?
Old 02-10-2008, 08:55 PM
n2ocamaro's Avatar
BMR Trak Pak here. I switch to a th400 so I needed a TA that mounted somewhere other than the tranny. Also its a pretty stout piece and adjustable.
Old 02-10-2008, 09:21 PM
mean94lt1's Avatar
umi tunnel mount here
Old 02-10-2008, 10:57 PM
BOLO's Avatar
I have the adj. tunnelmounted Spohn T/A w/ driveshaftloop.
Old 02-11-2008, 02:42 AM
Z-RATED94's Avatar
Same here. It's nice how it ties into my Kenny Brown double diamond subframe connectors.
Old 02-11-2008, 10:02 AM
StealthFormula's Avatar
I run a UMI and its great.
Old 02-11-2008, 10:11 AM
transamws6_97's Avatar
I run UMI also but have had problems w/ the driveshaft loop not clearing my driveshaft and hitting when my suspension unloads a lil over a big bump or hill. Really depends on what your goals are. If your looking at some serious fast times at the strip I'd go bmr
Old 02-11-2008, 10:34 AM
UMI Performance's Avatar
I assume you are running a 3.5" drive shaft? If so I am sorry, but it is hard as a manufacture to make all our items clear all the other manufacture items, correct? We recommend to use a 3" Chrome Moly drive shaft when needing to run a aftermarket drive shaft with our torque arm. This takes care of this issue.
For a aftermarket replacement torque arm we offer (2) direct replacments-
www.umiperformance.com/2206
www.umiperformance.com/2205
If you have any questions please ask. Thank you
Ryan
Old 02-11-2008, 10:40 AM
TwoFast4Lv's Avatar
The UMI stuff is great. The second one shown(adjustable) would be a great choice.
I have had to cut the DS Loop off the one mentioned even with a stock Drive. BUT That was two years ago Sounds like they have it covered now!
I would add this TQ Arm Relocation kit to the order for added adjustabilty and piece of mind
Old 02-11-2008, 05:34 PM
Thanks for the opinions everyone, I am going with a UMI adjustable torque arm with the relocator. How much did the torque arm help with your 60 ft?
Old 02-11-2008, 05:45 PM
30696bird's Avatar
I have a JEGS tunnel mount...I really like it. It's adjustable and very strong. I bought it because I have a friend with one and he's in the 1.4 60' range. It's fairly cheap too.
Old 02-11-2008, 06:11 PM
well mines a stock LS1 aluminum driveshaft so it's not really aftermarket....I talked to someone at UMI about it and they said there's nothing I can really do because it has to be made for so many different applications
Quick Reply: Torque arm opinions needed.
