stage 8 or breslin style ?
Old 02-18-2008, 07:25 PM
Pro_built7's Avatar
Default stage 8 or breslin style ?
what do you guys recommend for locking header bolts ?
Old 02-18-2008, 10:54 PM
Pro_built7's Avatar
soo should i even bother with locking header bolts or ...... ???
Old 02-18-2008, 11:04 PM
matt94z's Avatar
I've had good luck with ARP bolts and copper gaskets. I put a set of locking bolts on a buddies car and they were a real pain in the ***...
Old 02-18-2008, 11:08 PM
Pro_built7's Avatar
so do you think locking bolts are unneccesary b/c those darn things are pretty expensive you know??
Old 02-18-2008, 11:13 PM
Schweet97Z's Avatar
Where are you gettin Breslin bolts? I would get a locking bolt and Percey's Deadsoft Aluminum Gaskets. You will then be leak free!
Old 02-18-2008, 11:15 PM
Pro_built7's Avatar
well theres some listing on ebay for breslins, the only thing is they're not cheap and i don't want to get them if they're unnecessary you know ?
Old 02-19-2008, 12:04 AM
Village Troll
SS RRR's Avatar
No. ARP's w/ a 3/8" hex or 12-point, 1" long will do just fine.
Old 02-19-2008, 12:07 AM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
They aren't necessary. Some people want the added security of a locking bolt, and are willing to pay for it. Some feel it's a complete waste of money. It's not like your headers are going to fall off if you don't use a locking bolt. It's like choosing between stainless headers and mild steel. For me, anything less than stainless wasn't a consideration and I was willing to pay the difference in price. If I had not found some Breslin bolts, I would have used ARP's.
Old 02-19-2008, 12:16 AM
cookba's Avatar
i used stage 8 bolts and a percys gasket, no complaints
Old 02-19-2008, 12:21 AM
Village Troll
SS RRR's Avatar
Reminds me it really depends on why type of header used that can decide what bolt to go with (either Stage 8 or ARP at least). I tried to use Stage 8's on my Hooker LT's and there was no chance in hell being able to use the locks and it was impossible to fully tighten the front bolt and was also impossible to use a bolt on the back of the #3 primary between that and the #5 primary. These were 7/16 and were just not worth the trouble. Perhaps they work better for certain headers more than others.
Old 02-19-2008, 07:49 AM
BTC
BTC's Avatar
I know someone that used Stage 8's with Kooks. He left off a few of the locks because he couldn't get them on. That kind of defeats the purpose, imo. If you want a locking bolt, the split lock design is much better, imo.
Old 02-19-2008, 08:54 AM
matt94z's Avatar
That's what I use and they work great. Alot cheaper also...
Old 02-19-2008, 09:22 AM
Pro_built7's Avatar
ya thats exactly the thing i mean they are really expensive for bolts i dont really want to spend 60$ on darn bolts you know ?
b/c my stock ones were not locking and WOW were those a PITA they were NEVER coming out on their own you know?
i wonder if the aluminum heads has anything to do with it.
Old 02-19-2008, 09:48 AM
SS MPSTR's Avatar
Ditto. I ditched my Stage 8's - what a PITA.
Old 02-19-2008, 01:53 PM
69gto96z's Avatar
I used the stage 8's. Never had a problem. Had to "custom grind" some of the little slide on lock pieces, but got all of em on there with no problems.
Old 02-29-2008, 02:27 AM
Hustler00's Avatar
Default Bolts
I have used the Breslin's in the past. Pretty easy install. The Stage 8 and similar are a pain. You have to grind on the lock tabs like 69gto96z said to get them to fit certain tubes. Jegs and Summit have both discontinued this brand. Percy's are available. Just ordered mine but they are back order for about a month. Hope this helps.
Old 02-29-2008, 04:21 PM
Pro_built7's Avatar
ya i actually said screw the locking ones and went with regular bolts. honestly i just bought the 7$ jegs header bolts and i'll see where that gets me lol
Old 02-29-2008, 04:55 PM
caldercay's Avatar
Jegs and Summit have discontinued the Breslin's
because Percy bought out the bolts, so they are
now under the Percy name. I have Kooks on the
way and have been told that the Stage 8 would
have to be ground some. The Percy's wont be
in stock at Jegs or Summit until about April,
so will have to wait.
Spending money on Percy bolts is a drop in the
bucket when you consider the cost of Kooks/cats/y ...
... it's piece of mind.
Old 02-29-2008, 05:18 PM
ZeeTwentyFate's Avatar
they are not gonna come loose, i got the 12 point 5/16 bolts stainless through ARP and they dont even loosen up. the time spent putting locks on you could check them 18 times...
Old 02-29-2008, 05:22 PM
fergymoto's Avatar
I run Percy's gaskets and regular ARP stainless header bolts. I never have any issues.
