P0335 and P0336 crankshaft position sensor codes
I've been trying to figure out a misfire/crappy running problem, and I finally got it scanned. Here's all the codes I got.
P0154
02 Circuit-No activity detected (Bank 2, sensor 1)
P0160
02 Circuit-No activity detected (Bank 2, sensor 2)
P0140
02 Circuit-No activity detected (Bank 1, sensor 2)
P0335
Crankshaft Position Sensor A Circuit
P0336
Range/Performance
Now, my question, does that just mean my crankshaft position sensors are bad/missing/unplugged? Where are they located?
P0154
P0160
P0140
P0335
P0336
Range/Performance
By the way, this is a 94 Corvette LT1, in a 96 Trans Am. I used the T/A wiring harness, and it's still OBDII.
I'm wondering if maybe the sensors are different between the motors.. Anybody know?
No activity is when the sensor is not hooked up or the wireing is bad. The crank position code is well just that. Is it hooked up? Is the wireing good? It is also a early indicator that the opti is starting to have some issues.
