Loose oil
Old 04-06-2008, 06:07 AM
rsninja_57's Avatar
Unhappy Loose oil
Hello everybody !
My name is Jean-Philippe, and i live in France (sorry my English is bad). I'm new in this forum, and i have a Trans am LT1 1994.
I make some modifications : cold air intake, lightweight underdrive pulleys, hooker headers, off-road y-pipes, slp loud mouth, msd distributor, msd spark plugs wires, trick flow cylinder head...
But i have a problem, every 200miles i loose oil by my cylinder head, the cylinder head bolt fall.
What is the problem ?
Thanks you very much
Old 04-06-2008, 09:10 AM
camaro-94-z28's Avatar
are you sure your not loosing oil slowly and you just notice every 200 miles?
Old 04-06-2008, 09:21 AM
rsninja_57's Avatar
yes i loosing my oil slowly
example : in 40000miles i add maximun oil in the motor. In 40200miles, i look and i have no oil, i loosing by the cylinder head
Old 04-06-2008, 01:38 PM
slingshot928's Avatar
head gaskets?
Old 04-06-2008, 02:36 PM
highflyin's Avatar
Maybe the intake gasket(common)or the valve cover gaskets could be leaking.Wash everything down and make sure the oil is full.Then start the car and let it run for a few minutes and see if oil is leaking from somewhere.I doubt oil is leaking from the head gaskets.
Old 04-06-2008, 04:18 PM
97badass's Avatar
well hes losing oil BY the heads. so im going to say it is the all too common intake gasket leak.
Old 04-06-2008, 04:22 PM
97LT1's Avatar
I think this is the problem also.
Old 04-11-2008, 06:29 AM
rsninja_57's Avatar
Thanks you for your answer. But the trick flow cylinder heads and all of performance gaskets are NEW... It is strange
Old 04-11-2008, 07:13 AM
wannabess's Avatar
Did you put sealant on the front and rear rails of the block where the intake sits? You cannot put the intake manifold on with just the gaskets. I did a crappy little picture in case you do not know what I'm talking about.
File Type: bmp
Old 04-11-2008, 07:15 AM
sweet-94z28's Avatar
If you or your builder did not get the intake walls (china walls) clean enough, the silicone will not stick to it and you end up with your oil leak again.
Old 04-11-2008, 07:54 AM
Ironxcross's Avatar
If you're loosing oil, then you should tighten it.
Now if you're just losing oil, thats a whole different story.
Old 04-11-2008, 08:03 AM
wannabess's Avatar
He already said he was from France and wasn't the greatest at English
Old 04-11-2008, 08:57 AM
Ironxcross's Avatar
I still think it's funny. Maybe some helpful criticism will help him out? Who knows!
