Wiring issue with installing pacesetter long tubes
Old 04-06-2008, 01:54 PM
hbgben's Avatar
Default Wiring issue with installing pacesetter long tubes
I'm in the proces of installing the passenger side header and have no clearance with the wiring harness? Any ideas for re-routing this away from the header?
Old 04-06-2008, 02:15 PM
SnakeOiler's Avatar
do the best you can. keep away from the primaries, use some good zip ties.
Old 04-06-2008, 03:03 PM
the_merv's Avatar
I assume you mean the Wires on the right side that go to the Starter..?
Zip Tie them up to the side of the Body of the Car and keep them away. Also Wrap them with that Heat Wrap(Silver Duct-Tape lookin ****) or some Tin Foil if you have too..
Old 04-06-2008, 03:10 PM
SOM WS9's Avatar
I did what I could to keep them away from the headers when I did my install. The factory heat shielding **** did a good job, maybe too good. It stayed completely intact while the conduit and a ground wire inside of it melted.
I extended the wiring 12-14 inches and ran it forward, down, then through the engine mount to keep it away from everything. It's a simple and effective job.
Old 04-06-2008, 07:33 PM
Smokinlt1's Avatar
heat wrap around factory heat sleeve and zipties have been holding up for a year now.
