355 questions that need answers to them
ooookay... im thinking of a 355 build idk if it will be forged or not. that stuff is expensive. anyway what is a good grind cam for a 355 to make good power through the entire rpm range not just top end? it is a DD and will continue to be. i plan on building the trans myself and putting in a 3000-3200 yank converter. are the xfi cams any good? if so which one? also has anyone on here run the edelbrock lt4 heads? they any good?
Edlelbrock LT4 heads blow. You're better off with stock ported heads then wasting money on those. Advanced induction my first recommendation. Up to you on a forged rotating assembly, but honestly a custom grind is your BEST choice. Advanced induction does those as well. Loyd Elliot is another option.
