About to invest In these mods for my 94 lt1
1) SUPER STOCK yank 3600 4L60E/4L65E....price 675
2) PaceSetter Longtube ceramic Headers........PRICE 389
3) Y Pipe...........PRICE 115
4) Holley 58mm Throttle Body............PRICE 419
5) DruRic 69-0322-1 ..410 gears.........PRICE 181
6) 36lb Fuel Injectors.........PRICE 321.95
Grand total of 1810.95 + about 200shipping= $2000
This is what is needed for the lloyd Elliot Lt1 combo heads and cam, so Iam putting this on the stock ride(150 shot of nos, wont be sprayed) untill I save up another 2000 for that.
What do you think?
What do you think?
Well Iam hoping if everyone agrees that this setup is fine, then I will have the sponsors bid on my buisness so to speak. Iam buying all at one time, so if a sponsor can give me a better price then another Iam all for it!
1) TCI Stall 3000.....PRICE 489
What do you think?
What do you think?
IMO TCI does not make a good comnverter, you'll replace it later so do it right now. I'd go Vig then Yank. Gears is a 10 bolt are OK, if you plan on hitting the track it's a gamble. Save for a 9" or 12 bolt instead.
Forget the 58mm TB and buy a quality converter. You can have your 48mm ported to a 52mm down the road, which is more than enough. You won't need 4.11 gears if your going to spray. And if you do buy a nitrous kit, why wait until you have the H/C package?
4.10 gears will require taller tires or something done so that you don't shift into OD in the 1/4.
I hear nothing but bad things about TCI converters.
Also, with the LE heads/cam $2k sounds like LE3s right? LE3s you will probably want a higher stall. More like 3600. From what I've heard Yank is best for stalls that high.
+1 on the over kill injectors. If your running stock internals and not boosting with a turbo or SC the stock injectors or SVO 24# injectors will work fine as on the LT-1 the SVO injectors are actually rated around 27-28# with the higher 43.5 psi we run. Consider the fact I am running a 383 with SVO 30# injectors and that is plenty for my setup.
But with the H/C combo lloyd Elliots site says 58mm.
Yes Sir the LE3s, So a 3600 it is. Thank you.
