hay u yah u map sensor help
I'm going to get a new map sensor to install on my car. It looks farely straight forward on how to put it in is there any thing i should know befor i attempt it
you take out two small bolts.. should be 7mm or something. unplug it. put the new one on, put the bolts in.. plug it back in. if it takes more than 2 minutes, you're retarded
