LT1 and L98
Why the hell would you want to do that? Convert the L"98 peice of **** TPI intake" over to a Mini ram or a nice singel plane carb intake...
Then you have a choice of crazy SBC heads to work with..
SBC parts= Better than LT1 when it comes to racing and big numbers
LT1s spend alot of money to convert over to SBC heads
TPI 235HP @ what, 5K and 345ft/lbs
LT1 275-285HP @ 5500 and 320ft/lbs
So if he wants to swap over the LT1 heads, which are better than L98 heads, he'll pick up some more power. That's assuming he either has the LT1 heads, or has access to some for cheap (which they are anyways, $100-150).
OR go your route, spend more money, and get a mini-ram or a carb setup
Sure, the TPI's max RPM is like 5200, but it's not all that bad of a setup. You're just being like LSx owners are to LT1 owners, a jerk
If you swap on LT1 heads, instead of Darts, bordix or any of the other badass SBC heads then your a moron..Im sorry to say..
Now if its all your self, and you dont have to fork out cash then have fun
Well i found some guy on craigslist selling a pair of LT1 alum heads for 200.00.
and was just wondering if it would be woth the gain i would be getting over the l98s heads.
because im going to a carb setup over the TPI
But if your going to have to drop to much cash into it, look into a good sbc head
