3.42 to 3.73 is it worth it?
This is my first M6 car and I can tell the serious DRAG under 3500rpms compared to the higher rpms.... I want some lower gears but I hear that 4.10s are not good for the stock rear due to small pinon gears(or something like that)
Are 3.73's worth the swap...? or mabey 3.90s
3.73's are great in a M6.. that is what I have and am very happy with them
In my 99 T/A I had the stock 3.42's and I can tell you that there is a noticeable difference, so is it worth it yes, would I go 4.11's with a DD, prob. not, as I am happy with the performance the 3.73's give, and I still can get 28-29mpg on the highway when driving good.
Well, at your power level I'd say you'll be fine. My car is an M6, and I have 4.10s in my 10 bolt...I've ran several passes in the 11s and many more in the 12.0-12.2 range on m/t drag radials. Granted I don't dump the clutch and launch hard for fear of breaking it, but if they can hold plenty of high 11/low 12 sec passes in my car, I'd say you'll be just fine with 4.10s in yours. Just be sure that they are set up properly, and I would advise you to use a TA rear girdle (or similar product) and stud kit.
Oh and as far as rpm on the highway, I turn 1800 @ 60mph.
I would go with 3.73s, but I feel the swap from 3.42s isn't worth it too much. Plus, I get great mileage as it is and I barely ever beat on it.
Damn you auto guys have O/D and you're still complaining? My '78 has the B/W T-10 (no O/D) with 4.11s and redlines at 5K... and it's great!
