LT1 Top Stocker
Old 04-14-2008, 11:31 AM
GIZMO's Avatar
Default LT1 Top Stocker
I have finally loaded a few pictures of my LT1 Top Stocker into my Photobucket account and thought that some of you might like to see them.
Engine Bay
Front
Rear (6.58@103 mph, stock unported heads and intake, stock throttle body, 24 lb injectors, approx. 360 ci, N/A, 3000 lbs race weight)
Old 04-14-2008, 11:39 AM
Formula350's Avatar
Doesn't look stock to me You have my valve covers
EDIT: Oh now there's more pics -_- I see what you're talking about now heh
Old 04-14-2008, 11:41 AM
96capricemgr's Avatar
That's pretty.
Old 04-14-2008, 12:34 PM
robsquikz28's Avatar
looks nice tho
Old 04-14-2008, 02:01 PM
DADDY&GIRL93TA's Avatar
Very nice.Got any Interior shots?
Old 04-14-2008, 02:04 PM
hashtagBMW
Speed Density's Avatar
Looks good! But why the LS front end?
Old 04-14-2008, 03:05 PM
Tireburnin's Avatar
I like how it says 24lb injectors and then I look at the back of the rails. The light weight engine control harness is nice too. Should the description of parts used include more quotes around them indicating the term is used loosly?
Haha looks nice and clean. I like it.
Old 04-14-2008, 03:14 PM
LT1MAN's Avatar
i thought i recognized that dump *** track. i hate moorseville dragway.
runnin 6.5's with stock top end is impressive, any plans to change that?
looks like you are taking a good bite up there, whats your suspension setup?
Old 04-14-2008, 04:44 PM
Racin96ss's Avatar
Looks nice...
Old 04-14-2008, 05:13 PM
Toronto_LT1's Avatar
nice,clean set up.
dyno #s??
Old 04-14-2008, 05:14 PM
Tony Shepherd's Avatar
Very clean installs! Have your shock towers been cut and re-welded?
Old 04-14-2008, 05:17 PM
GIZMO's Avatar
I will take some the next time that I take the car out of the trailer. It has a ten point cage, full interior including headliner and light weight carpet, and one factory cloth seat (required for Top Stock).
Old 04-14-2008, 05:22 PM
GIZMO's Avatar
In 1998 when GM submitted the specs. for the Firebirds they listed the LT1 instead of the LS1. I think it was done because there weren't any LS1's available for racers and GM wanted the later body style at NHRA/IHRA races.
I purchased the entire front end new from the dealer in 1998. The car is a 1995 Formula with AC delete as it's only option. It has been a race car it's entire life and shows 000186 original miles.
Old 04-14-2008, 05:27 PM
GIZMO's Avatar
I figured out a long time ago that a good high pressure/high volume fuel system is a must. That is why I have #8 AN fuel lines and a #6 return. The injectors are 24 lb SVO's run at 50 PSI.
Old 04-14-2008, 05:33 PM
GIZMO's Avatar
1. Greg Anderson and Jason Line test at Mooresville.
2. The car has more in it. The rules for Top Stock are pretty tight. The motor has stock rockers and a stock lift cam (.449/.460).
3. I will post up some pictures soon. Almost everything came from BMR. So far the sixty foot times have been around 1.37. They should be in the high 1.2's once I get everything right.
Old 04-14-2008, 05:35 PM
GIZMO's Avatar
I welded all of the seams for strength. We are not allowed any bars ahead of the firewall.
Old 04-14-2008, 08:27 PM
flyinZ's Avatar
Am I missing something?....I just dont get, how a stock cammed, stock intake, small injector-ed car, can run 6.5's....
Old 04-14-2008, 09:01 PM
94nitrousedLT1's Avatar
Stock lift is not stock cam. The cams in these cars have an aggresive ramp rate and actually throw the valve open to achieve higher lift.
I wonder what the car weighs?
Old 04-14-2008, 09:28 PM
Prototype007's Avatar
I love your T/A dude!!!
Old 04-14-2008, 09:29 PM
I8ASaleen's Avatar
Says 3000lb race weight, but damn howd' you do that!?
Quick Reply: LT1 Top Stocker
